Help creating a non smooth emulsion finish / fine textured
13 Jun 2011
Suffolk
Since a repair i carried out to our stairs wall and then skimmed the repaired area the wall finish was smooth
When painting using Dulux emulsion the colour match is good but the difference in surface finish is too smooth compared to the main part of the wall and stands out
The main finish on the rest of the wall is a very mild orange peel look, as i do not want to finish the whole wall my question is
1. how can i paint emulsion and have a very slight textured orange peel finish ?
i have tried a paint pad and dabbed at the repair to "lift" the paint to create and it nearly worked !
What would be the better way to match the finish
Incidently the repaired area has direct light falling on it and as a smooth finish stands out badly
Please help if you can
I should send my brother-in-law round. he can achieve any amount of orange peel by laying the paint on really thick with a crap long pile roller sleeve.
Magnificent!
Thanks its not every day you get a request for a non smooth finish !
The finish i am after is not exactly orange peel more a textured finish but very fine textured
I guess under normal wall painting the roller would lift the paint to create the effect, when i go over the skimmed area it dries very flat, too flat !!
Any ideas ?
use a long woven roller, roll a coat on but dont roll out. let set up for a while and then run the roller over it again, this should add a bit of stipple which will dry as orange peel
I take it you used dulux retail paint which is designed to dry out smooth however applied
the wall was probaby originally coated with a trade paint which was used too thick to flow leaving a roller stipple
Thank you that is very likely the case, some of the rooms and very smooth, the hallway and stairs are a textured finish all be it very slight
I will try the trick suggested with the roller and see if that helps
I have always been happy with my skills with emulsion but this was getting me down as its so obvious a different finish because of the skim coat ( the patch repair area is approx 3ft x 2ft )
Thanks again
