Help! Didn’t mist coat on plaster.
1 Feb 2022
Hi all,
I think I made a big mistake. My plasterer recommended using Zinnser on the skim coat when it was dry. In the past I always did a mist coat but because this was an external facing wall I thought it was a good idea and assumed he ment straight on. So I applied the zinnser to both external facing walls and the fireplace.
Will it be ok? Looks ok.
Should I sand it down back to plaster?
What’s the worst thing that will happen or what’s more then likely going to happen?
Any help would be great.
Thanks.
Zinnser is just a manufacturer. What product? What is your objective?
Mod
Update, I used the Zinsser cover stain
primer-sealer stain killer. It’s been on the wall over a week and I can’t see any issues yet.
I hear some use Bullseye 123 on plaster but your the first to use coverstain.
It's on now so carry on. Be fine.
Just spend 1 minute reading the application data sheets for paints as will save you the grief in future
