Help - emulsion paint on tiled floor
JCH
9 Jun 2008
Gloucestershire
I have just finished decorating the conservatory. Thought I had been careful but there are various emulsion paint stains on the tiled floor. Have tried removing with warm water which removed the top layer. Has anyone any ideas on how I can get more of the stain out? (before my husband sees them in daylight at the weekend!!)
27 Nov 2007
Surrey
What sort of tiles are we talking about. If they are ceramic glmazed tiles it should be easy if they are natural unsealed tiles the pigment of the paint could soak into the surface.
9 Dec 2008
Birmingham
i would suggest you try white spirit or paint brush cleaner, before you apply to the stain try the solvent on a spare piece of tile just to make sure no further staining occurs. Are the tiles glazed/faced or quarry tiles?
14 Mar 2006
Kent
Don't use white spirit , not suitable for emulsion and may permanently stain grout.As Diyisfun suggests and a green kitchen scourer also helps.
11 Sep 2007
JCH - cellulose thinners will readily soften emulsion paint. A few drops on the offending spots, leave it to soften the paint, scrape/scour/wipe off. Then rub that whole tile with a rag damp (not dripping) with a little thinners.
Cellulose thinners is available in 5L, 2½L (clearly too big for you) or very small cans (you can get these in B&Q I think).
23 Feb 2007
Gloucestershire
Thanks for your comments. I've tried white spirit which didn't work, so I will give the cellulose thinner ago, unless anyone still thinks they have a better idea.
27 Nov 2007
Surrey
Try the green pad and then if that doesn't work try some fine wire wool.
You can get fine wire wool from a decorators merchant, probably not from the sheds. Cellulose thinners in a small 250ml tin from a car accessory shop.
Try a drop of boiling water straight from the kettle. (I have rescued a few paint brushes this way :) )
Good Luck
15 Nov 2005
Gloucester
Cook Islands
methylated spirits softens emulsion paint and does not smell much or damage most things. It will harden again when it dries, so mix with washing-up liquid and dab it on with a paintbrush. dab on some more to keep it soft. From time to time rub it with a nylon scourer to see if it is soft enough.
The washing-up liquid also makes it easy to wash off.
9 Aug 2010
Suffolk
ive got the perfect solution and i swear by them. industrial wipes or gorrila wipes you get from a builers mechant. i used to get customers that couldnt remove marks or stains with ciff and other strong products but i used the industrial wipes and they work a treat, and they wont harm you tiles, or your hands. i use them every day to get oil based paint off my hands, even gets the silicone off my hands and thats water proof.
