Took old kitchen apart, about the only thing my better half wanted to keep was the monobloc tap that was on the sink. It wasn't in the right place for the new sink, so I cut it off by the rigid tails it was on and fitted isolating valves to the supply pipes... with the intention of extending from these and joining to the monobloc by 300mm flexi pipes once the new sink is in.
BUT the tap doesn't have standard size fittings..... and, of course, in an unusual bout of tidiness, I've binned the rigid tails that I took off (they were soldered, short and messy - "won't be needing those again!").
All the monbloc flexis I can find locally or online have 10 or 12mm fittings at the tap end.... the holes in the tap are a little bigger than 12mm tho the fitting just slides in a little bit clear with 12mm.
Anyone any idea where I could find anything to fit?
TIA
TIA
