HELP-Glow worm 30cxi heat exchanger dripping/losing pressure
23 May 2005
Merseyside
Glow worm 30 cxi Boiler losing pressure . After being turned off at night I am having to repressurize each morning after which it works ok. Outside the end of the copper pipe that connects to the pressure release valve inside the boiler is dripping. Also water dripping from base of boiler - so after removing the covers I finally discovered this morning that water is dripping from the bottom of the heat exchanger chamber , this then stops
and will no doubt re-occur tomorrow after re pressurizing and turning on the boiler. Any advise please?
Brian
Ouside pipe drip is covered FAQs - boiler pressure problems, etc.
Leak in side sounds like it needa a Corgi to investigate.
