help !!! gloworm compact electronic hot water no heating
17 Jan 2007
Lancashire
freeeezing :shock: :shock: :shock:
please help.....i have a gloworm compact electronic.......the boiler fires up when calling for hot water but does nothing when turned to c/h..... :?:
we had problems with this boiler & recently had a new pcb fitted which sorted previous problems.....now it is knacked again..... :(
any ideas on what i should be looking for to fix pls asap.....were bloody froze & have a young baby & no other heating,plus we are pretty skint at the minute.... :? :? :?
any help greatly appreciated,regards sue.
Does the heating LED ccome on when the hot water/heating button is pressed on the front panel?
Perhaps a problem with the room thermostat or timeclock.
The only othe likely problem would be the flow thermistor however, if the pcb was fitted recently it would have come with a new flow thermistor - was that part also fitted?
