I noticed a small drip from the header tank and finally went to investigate - no sign of a leaky valve - but the tank was read hot? This was never the case before the pump was replaced in May this year.
On investigation I think that the pump is the wrong way around but how can I be sure? I think I am right as:
1. The hot water is entering radiators from the opposite end to the Themo-valves.
2. The flow is towards the expansion-header tank feed (away from the three-port valve). The pump actually looks upside down too.
I have a Glow worm Space Saver II boiler (none-combi) but don't have a manual to know which is the flow and return. Anyone help?
