Help identify shower waste
21 Aug 2025
Can somebody help identify the shower waste in the attachment please? I need to find a replacement flange and tube, but the common tube width of 63mm is too wide. I’m at a loss as to what the make could be or where to find spares.
Thanks,
Max
Sometimes the waste matched the tray.
I guess you can't see any labels under tray showing manufacturer?
I did order X2X waste by MX group thinking the tray was Minerals. The grate matched, but the tube is a bit too wide and doesn’t fit in. Makes me think the waste was not by the tray manufacturer.
What’s unusual is that there’s a rubber o-ring on the above screw. Typically tubes just hang off plastic, and the flange comes with the o ring.
Having failed at id-ing the waste, I’ll 3d-print the missing parts. I thought it might be possible to tell the waste’s type. I was looking too much at common wastes, which seems like this one isn’t.
