Help identifying hose
20 Apr 2009
Norfolk
The hose connecting my toilet to the mains supply was leaking last week so i've isolated it and looking to replace the hose.
I've attached images of each end. It looks to me like 1/2BSP, male one end and female the other.
Can someone confirm and perhaps give me the proper name for it so I can search the internet for a replacement.
It's more likely that the connection at the fill-valve is leaking, especially as there looks to be PTFE tap in the threads.
There should be a washer in the end of the flexi that the valve tail seals to or, more likely, the (plastic) threads on the tail have been damaged by either over-tightening or cross-threading.
If the washer is missing then http://www.screwfix.com/p/arctic-products-flexible-tap-connector-washers-10-pack/2035j
If the tail is damaged then a new fill-valve is needed - choose one with a brass tail to reduce the chances of damaging it http://www.screwfix.com/p/fluidmaster-bottom-entry-brass-shank-fill-valve/47792
Edit:corrected link
