I had the heating on continuously on Christmas day. When everyone had gone, I switched the programmer back to its normal 'twice' setting, but the heating continued to run. I then tried all the programmer settings and it continued to run on all settings, including 'off'. Also, it would not shut down even when the room thermostat was set to minimum. In order to avoid roasting overnight, I switched off the electricity supply.
In the morning I switched the electricity to the boiler back on, and it was exactly the same. We were out for most of the day, so I turned the heating control knob on the boiler to 0 (and left the electricity supply on). The boiler/CH did not run.
When we got back home I turned the knob on the boiler back to its normal '3' position. However, the CH did not run. On fiddling with the programmer, the boiler would fire, and the pump would run, when the hot water switch was used. However if the heating switch was used, the pump would stop and one of the motorised valves would buzz. Manually opening the motorised valve made no difference.
So what is likely to be going on here? On Christmas day my thoughts were that the boiler was faulty. Today it looks like a motorised valve is now (also?) faulty, but I'm not sure the valve alone can explain all the problems.
The boiler is a Gloworm Fuelsaver, last serviced 3 weeks ago. The programmer and motorised valves are Honeywell.
Any suggestions gratefully received! I have service cover on the boiler, but not on the programmer or the motorised valves.
