Hi All,
Couple of types of fixing that i've come across recently which would be very useful but I cant find them anywhere as I dont know what there called.
First one I can only describe as looking a little like a strip of mechano, I've mostly seen it used for supporting cable runs in ceilings and on walls above suspended ceiling tiles, they look similar to millie ties but are made from maluable metal.
Second one is a fixing which ive again seen used in corrugated ceiling. It is basically a threaded insert, the ones i've seen have always been brass. I would imagine you have to drill a correct size hole, clip in the fixing and then you can screw say an M5 screw into them.
