Partially threaded Direct concrete fixing fasteners
30 Oct 2019
The last lot of builders I had in used self-threaded concrete fixing for just about everything, saving them from having to mess around with rawl plugs. They seem pretty nifty. Obviously you're not going to hang a picture frame up with them, but for other stuff they seem ideal - like fixing stud wall fame to external wall.
I've not been able to find any partially threaded screws though, wondering if there is a reason for this? I can always widen the hole in top material if I want it to pull-to but I've always like to use partially threaded for this purpose.
Your builder used concrete thunderbolts.
You asking about plain shank screws or plain shank thunderbolts. You can get plain shank thunderbolts.
Full thread will pull in , they are stronger than both timber and brickwork .
Sounds more like torx head masonry screws.
Yeah although you can get thunderbolts with hexagon flange heads
I've never looked to see if thunderbolts are different to concrete bolts tbh
