I'm having a problem, fixing a batten a wall to then hang some heavy wall cupboards.
I tested a section of the wall which will be hidden, and it's approx 20mm of plaster over aerated concrete block (possible aircrete?). It's a 90s house, there is obviously a cavity and normal brick past the concrete block, just in case that's important!
Clearly I couldn't hang heavy cupboards on plaster, so I thought it'd be best to find a long set of plugs/screws, drill through the plaster and well into the concrete block to ensure a solid fixing.
Couldn't find any normal wallplugs that were long enough so finally found some overpriced "frame fixings" from Wickes, 100mm long requiring a 7mm masonry drill:
http://www.wickes.co.uk/Universal-Frame-Fixings-8x100mm-PK4/p/190042
Theyt are slightly different to the picture, more like normal wall plugs, but longer, with the usual lugs and fairly hefty screws which appeared to expand the plug well. I wrongly thought would give a good fix.
I'm sure you can guess the next bit.
Drilled the correct sized and depth carefully, the concrete block is like butter even on slow speed (obviously no hammer action!), tapped in the plug, started to screw up the batten, 1/4 way in the plug starts spinning, and the hole is getting bigger. Zero chance of a solid fixing.
It's obviously the crumbly aerated block, and now I wish I hadn't followed the instructions and drilled a far smaller hole, but there you go.
I've looked at this thread btw, but want to check advice (as this got a bit ranty!):
//www.diynot.com/forums/viewtopic.php?t=238873&start=30
Managed to remove the plugs, which are now mangled. However no damage to plaster, but I suspect the hole in the concrete is quite a bit larger. What's the best advice, try to pack out with something first, or try some sort of fixing glue? Issue it it's a 100mm deep hole.
(As I have 2 similar battens to put up, what would be the best approach for the next one too, advice on plugs/hole size etc, needs to be heavy duty, two heavy will hang cupboards from the battens.)
Thanks all, and Happy Easter!
