Please can somebody help me, I have just punctured the hot water feed to a radiator. The feed is via the modern plastic pipe and has sprung a minor leak. I have patched it up using nylon jubilee clips and a cycle repair patch.....what do I do next.
I kinda didnt mention that the hole was behind plaster board, it is now visible thanks to my trusty chisel. The one thing that is baffling me is how do I stop the water supply to the raidiator.
Do you know where the drain stopcock is ? Then shut down the water supply to your radiator system & shut down all radiator valves then drain it. You don't say what system you have , is it a combi etc............
Okay I'm trying to help you to stop the leaking quickly, turn off the programmer that operate the radiator and shut down all radiator valves.
If it's a combi there should be a water supply stopcock to the boiler somewhere, shut it down. (hot water will be unavailable at this time)
If you don't have a combi, do you have a small tank (Feed & Expansion tank) in the loft not the big tank (Cold water storage tank). Shut the water supply to the small tank. Do that first then find the lowest drain point for your radiator to drain.
