Hi Guys,
I'm looking to lay a new floor this weekend, either laminate or hard wood and I want to hide some cabling underneath it. I have speaker cables front and rear, a sub cable, phone cables and the input to my sky hd box I'd like to hide. I figured loads of companies made some sort of underlay with conduit built in for this prupose except I cant find any so I'm thinking of making my own...does anyone have any experience of this??
What I'm considering is cutting out a channel of the foam underlay and embedding the cables in it, if I think I have enough cable to route it around the edges, say 15-20cm from the expansion gap as it won't get walked on or have as much use on those parts on the floor in that area this is what I'm looking at
Can you guys think of anything I should take into consideration when doing this? A particular type of underlay? Should I leave a gap between the squares and run the cable there or cut out just enough for the cable?? Also any idea how I should leave the edges where the cables come out? Just leave a gap in the beading??
Thanks guys
Ross
Thanks guys
Ross
