Hi;
I am separating a room with a stud wall and fitting a door frame (but no door yet). The door frame has a header and two uprights (like this). The header has two sets of mortice recesses one pair on either side, where I presume the uprights fit. On one side the inner edge of the recesses are 76cm apart and on the other side the recesses are 84cm apart.
The door linings are 25mm thick.
We are not planning on fitting a door, because if we do it needs to be a fire door, so for the time being we are leaving it as an opening.
I have marked our all the studs working from either wall and currently have a gap of 102cm where the door way will go.
Adding the thickness of the door linings (25mm) to the widest recess in the header the external size of the door lining would be 89cm so I will move one of the studs that sit either side of the door to meet this (or double up a stud to keep the 400mm centres.
Questions
1. Are the recesses designed to allow for two different size doors?
2. Should I use the wider option?
3. What size door would be needed if and when we get one?
4. This is a softwood door lining, so if we had to get a fire door would we need to replace the door lining.
I am kind of up against it because I need to get the stud wall finished tomorrow night (at least the lower part because the flooring is going in on Thursday PM.
Thanks for any advice
Questions
