Help! No hot water but CH is ok. Vokera boiler not firing
26 Dec 2011
Glasgow
I have a Vokera 20/80 RS Flowmatic boiler which until today was working perfectly well. Now I'm suddenly getting no hot water from the taps. The boiler does not fire up when I turn the tap on like it used to. Pilot light is lit and the boiler fires up ok when I switch the CH on. I also get hot water when the heating is on so really the only problem is no hot water on its own. Is it likely to be a valve issue somewhere? TIA.
Its likely to be a failed diverter valve.
If you are calling someone then try Danny of Ranoch Services, its his favourite boiler model!
Tony
  • Thanks
Reactions: DP
It may only be the diaphragm, and therefore a simple job to rectify. Bit of dismantling to do but a good pro would complete in an hour.
David what you have is a good boiler that a boiler fitter would say is too old to repair and a heating engineer can sit on a fence and be able to recommend a replacement or repair. A tree hugger like myself would suggest an overhaul that will give you a few years more from this brick outhouse of a boiler
