help, no hot water
8 Feb 2005
I need the help of men who can empathise. I have no hot water and a pregnant wife who is not happy about the situation!
I inherited a fandabidozy 'Ravenheat 820/20' combi when i moved to my current house nearly a year ago. I am aware that these boilers dont have a great reputation, but unfortunately i am stuck with it until i have the pennies to buy a new boiler.
I had a very similar problem with the combi in my old house and think it may be a problem with the water as well as the boiler, here is the problem:
Boiler pressure is fine, over 1 bar, heating is working fine, but no hot water, the pressure of the water leaving the taps has declined over recent weeks and i now barely have a drip. the water is hot when the heating is on though.
I am guessing there is a problem with the diverter valve and /or the the heat exchanger is scaled up (this was the problem i had in the old house- very hard water, no flow through h/e in that case because of scale as well as problem with diverter). I cant hear the microswitch click when the tap is opened, i could until a month or so ago.
should i try the h/e first, before buying a new divertor?
any thoughts???
Funny that...
Had same boiler with same problem yesterday. No limefighter fitted. It also seemed to me that this design is a 'limescale disaster waiting to happen': direct-heated HW exchanger which is bound to run at above the 'critical temperature' (for depositing 'temporary' hardness) when there's no flow of hot water. ie. most of the time.
I already condemned it as 'beyond economic repair'. There were leaks and other damage elsewhere in the boiler. But maybe I shouldn't have....
Perhaps Kevin will tell us more about the effectiveness of descaling the hot water heat exchanger in-place... I take it you meant: connect a machine across the hot water feed and cold water inlet connections. Well, OK - but what about the diverter valve diaphragm??? Given that on an oldish boiler this is going to be a bit flaky, what's the descaling chemical going to do to it? And which descaler to use?
you can do it that way i prefer just to connect to the h/e
then dont have the problem with the valves
i usally use kilrock
agree about flaky h/e the black viallant 1s where a git for perforating
as where the s/d
which i assume is the design you refer to
