- Joined
- 29 Sep 2022
- Messages
- 2
- Reaction score
- 0
- Country
I hope someone can help here. Sorry if this a long post, trying to anticipate any questions.
I have a Worcester Greenstar Si Compact Combi Boiler with a Salus ST620WBC Thermostat. Installed Feb 2015, so 7 & half years old.
I noticed earlier in the week that the heating hadn't come on when the temp dropped below 18.5. looked at the boiler, and there was a flashing red LED. After a bit of Googling, I figured out that the Thermostat was no longer paired. Probably from earlier in the year when I noticed the thermostat was dead & replaced the batteries. Until this week temp hasn't dropped low enough for the heating to come on.
I saw somewhere that to stop the red flashing light and get it ready to pair, I needed to turn off for 5 seconds. Turned it back on and flashing red light had stopped. So far so good. But this as far as I can get. I cannot get the receiver (this is the bit connected to the boiler right?) into pairing mode. If I move the switch all the way to the right, the boiler fires up, but when I put it in auto (middle position) and press & hold the Sync button, it does not flash every second. Tried pairing from the thermostat itself anyway, and it does go into the pairing mode here, counting down from 10, but does not pair.
Is the receiver just broken? Or am I missing something I should have done to reset and forget the previous pairing?
Thanks in advance for taking the time to read and respond.
