Hi All,
I am hoping for some advice. I am having a rear door bricked up and replaced with a window instead. At present it currently has a door contact fitted with eol resistors which is no longer required as the window will only lead into a utility room(external to this area is covered by PIRs). I have unscrewed the contacts for the time being and taped them together to fool the alarm so that we can still set it. However i would like to remove the wiring from within the panel. I assume that if i do this i would still need to fit the eol in the panel to fool it into thinking that the contact is still there. Can anyone please confirm if this is correct and confirm which resistor will need to be fitted in the panel. Please see the images below.
I am also having a new front door fitted currently there are flush contacts, i have not yet had a look at it properly but i am assuming it would be wired in a similar fashion? I would like to remove it from the panel temporarily while the old door is ripped out in the same manner as mentioned above. The door fitter is going to install a new cable within the door frame to the bottom of the door where i intend to fit some new surface contacts at low level I will then join these to the existing cable at high level. Is this acceptable? I may be able to hide the joint in the sounder box which is adjacent to the front door so technically it is in a tamper proof enclosure or could fit a separate joint box, does the JB need to be tamper proof if the wiring has eol fitted? I am hoping to fit a smaller more discreet set of contacts then shown in the pics below is there any particular type that i need?
Finally when working in the panel is there anything i should know? Do i need to isolate it to work within the panel? Can i disconnect the contacts whilst still 'live' or is this likely to blow an internal fuse? I do not know the engineers code but assume i can silence the alarm with my user code if it starts to go into alarm or fault.
Any help would be greatly appreciated. Thanks in advance.
