I understand what to do except this:
"Where necessary connect a fixed earth wire to the earth terminal on the accessory and then connect a short length of wire from the accesory earth terminal to the earth terminal in the wall box. If the earth wire is bare it should be sheathed with a length of green/yellow sleeving."
I have a chrome dimmer switch from homebase that i want to install. It has a green/yellow earth wire fitted to the plate. Do i just connect the end of that to the earth terminal in the wall box?
The instructions make it sound like i use 2 wires, bother running from plate earth terminal to the wall box earth.
Thanks in advance for your help
