help plugging leaks in garage roof
4 Nov 2011
Gwent
Hi all
I am a newbee to the site and would appreciate any help in my limited knowledge of home DIY.
I have a problem with my garage roof, the previous owner bolted wooden beams to the roof which is causing the rain to seep through where the bolts are fixed.
I plan to plug up the gaps and also paint the outside of the roof with weatherproof sealent, I also want to add antivandal paint.
I have some idea what paints to get, but not sure about what to use to seal up the minute gaps in the roof bolts.
Can anyone give me some advice of the best way to do the whole job and ensure a dry garage.
Thanks in advance
If you can remove the bolts, then you can refix with a EPDM washer or make your own from a EPDM sheet.
Otherwise use a good quality silicone or butyl roofing mastic - but ensue it is compatible with whatever roofing sealant you will use
If these is corrugated sheets, then the bolts should be on the upper ridge and not in the troughs - or they will always leak
Just to add what Woody said, get the Form Flash EPDM, you can get it by the metre, at 225mm wide and a small tin of primer.
Cut out some disc shapes to size required, prime area, stick patch.
