Help, problems setting up Pyronix XDL12TT-WE WIRELESS OUT DOOR DETECTOR
13 Nov 2021
Hi, I’m new to this forum and hopefully someone can help.
I have a 2017 wireless pyronix enforcer alarm system. I have just bought a XDL12TT-WE WIRELESS OUT DOOR DETECTOR . I am having massive trouble setting it up. I just want it to send me a notification to my phone if someone walks down my drive. But I don’t have a new enough panel to set it to switcher. Is there any other way I can set it up.
Also not sure what input type to set it to, as I don’t have the switcher option.
2 Feb 2016
Newark
If you do not have the switcher zone input option, then your control panel does not have the correct firmware for this function to work.
13 Nov 2021
Thanks for the reply, I get that. What way would anyone set this up now then?
2 Feb 2016
Newark
The firmware needs upgrading.
Pyronix are the only people that can do this . This is not usually available for end users,but installers can ask for assistance.
13 Nov 2021
Bigsosij, would you be able to tell me the process you would do?
17 Jul 2020
W.yorks
Once you have learned the device to the panel u need to go to change inputs and if you go through the input types u should have switcher? Unless it is a very early v10 then maybe it doesnt ?
2 Feb 2016
Newark
Go into engineering function
To find software version press no until Software Revision?
Press yes
Display will show panel version
Rev V10.20e
If not then firmware upgrade needed.
13 Nov 2021
Is there a way I can go about updating the software without having pyronix do it. As I don’t have a maintenance contract with anyone
