Cold tap valve has overtightened so trying to get to it... and failing.
I've removed the end cap, and the screw inside but still can't remove the handle. There is a couple of mm play in the handle when I pull it out but then sticks firm. There is no grub screw anywhere on the handle shaft. There is no grub screw under the tap itself, or on that cover (which looks like it might unscrew but pretty sure it doesn't)
Pictures here https://imgur.com/a/6O51bsQ
Any ideas? It's driving me crazy!
