I have a leaking Bristan Orta bathroom basin tap and want to replace the cartridge on checking the booklet maintenance page the removal instructions mention/show first the handle then below that cap and grub screw. Checking the tap no cap and grub screw so I understand the handle has to be removed to gain access to cap and grub screw underneath. That's where I run into a problem how do I remove the handle? (yes I have turned the water off) that handle is on B****Y tight advice please. Oh and is there anything else I should know about this tap?.
Thanks in anticipation.
