Help replacing Drayton with Hive
21 Aug 2022
looking for some help installing a Hive 2 channel controller, replacing the current Drayton controls on my Greenstar 24i
current setup
Greenstar 24i system boiler
clip in Drayton controller for Heating and Hot Water
wireless Digistat +3rf as the thermostat controlling the heating
this currently works with the water timers set on the clip in controller and the heating set to ‘on’ with the thermostat then sending on ‘ off commands.
i want to replace the controls with a 2 channel hive thermostat so both hot water and heating are programmed and controlled by the one device.
so far I have read the guides on here and it isn’t working:
in boiler remove LR to LS link
connect LR to 3
connect LS to 1 with a bridge between 1 and L
connect NS to N
what am I missing? Does anyone know how to make this work?
You’re trying to wire it up as a single channel receiver. You need to tell us what motorised valve(s) you have.
