I need help
I got a guy to cut my counters for me. However when he had done the joint he discovered that the sink had to go on top on the joint. This is not good I know but it is the way I am now, I don't need people saying I would not do that as I know this!
He said he would let the joint set for a few days then come back and cut the sink out. He put the butterfly joints under the counter. However his mum is ill and I cannot get hold of him and am fed up of washing the dishes in the bath.
Can I cut the sink out without causing the two worktops to pull apart, or do i need to screw some metal joining bars under the counter for re-inforcement? The sink cut out will be the whole sink with a 30mm lip around to support the sink.
Any suggestions will be gratefully received!
