Hi.
My washing machine (Appliance) Valve leaked water when being turned on and off so I set about changing it. I got a Plumsure one from B&Q as Screwfix were out of stock. I followed what I beleive to be the correct procedure with of course no PTFE tape and copper pipe:
- Saw off pipe to get rid of old Olive
- File the end of the pipe square
- Clean up the edges with wire wool
- Fit new valve fingure tight with new Olive
- Tighten with a spanner by 4/6th of a turn
- Watch for drips then tighten by 1/6th of a turn
Over the course of the afternoon I kept tightening it up after seeing drips appear until I had tightened it over one and a half turns and the leak rate was getting worse. I took it back and got a replacement which seemed OK for a few hours then did exactly the same. The machine was not connected (just had the valve turned off).
I then went to Screwfix and got a JG Speedfit push fit one. I bought a compact pipe cutter and cut the pipe clean. I smoothed off the edges with wet and dry paper before flushing a bit of water through. I measurted the hole in the valve then marked the distance on the pipe. I have put the new Speedfit one on with ease however It feels so light I can not beleive it can take mains pressure and Im reluctant to turn the water back on!
A couple of questions:
- Are these light, flimsy feeling Pushfit connectors generally up to the the Job to use for this sort of aplication?
- Was I doing something wrong with the Compression version or is it common for Plumsure to supply "Dodgy Batches"?
Thanks in advance.
Thanks in advance.
