- Joined
- 27 Jan 2008
- Messages
- 29,247
- Reaction score
- 3,588
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
Because of the loop system we use where the DIY'er starts to play it is common to find the fault at a lamp that works.
Remote from the job I can't say if this is the case with your set-up. But often the house holder does not give the electrician full story until after it is fixed and in doing so get a bigger bill as it took the electrician longer to find the fault which is why I said tell the electrician all you have played with including those that work to keep your bill down.
