I moved in a new house just over a year, lately the gravity feed shower system start giving me trouble.
1. the water pressure graduatelly reduce pressure after the pump working a few minutes, then run out of water.
2. I replace a new watermill brand shower pump two weeks ago (I have tried 5 different pump before and it was the same problem as above mentioned, just doesn't work at all), it was working all right until now. however, the same problem seems return again, the shower water pressure starting to reduce again!
3. I have changed all gate vavles on the loft before I change the pump, it was a limescale stop the vavles supply efficient water flow before. after my friend gave advice to check those vavles first and change them if necessary, so I did.
however, the problem has returned again, I run out idea what could possibly cause and how to fix it. Would you all kindly give me some advice how to fix this problem please?
Thank you[/quote]
Thank you[/quote]
