Hi Everyone,
I am in need of some advice about my existing shower pump.
I have a multi function steam shower that is supported by a Salamander CT75 Twin pump. The pump is sited close to the shower but below the shower head. Effectively water is fed from the tank located in the loft down through the pump and pumped back up to the shower head.
My problem is the that the pumping action is intermittent as though there is an air lock in the system. This causes a drop in pressure and impacts the strength of the water flow through the shower. This morning it appears that the pressure to to the overhead shower has dropped so low that the water flow Has reduced to a trickle, indeed the pump did not kick in when operating the shower. I would say that when I switched it to alternative shower head the the pump did start running but again the pressure was intermittent resulting variable water flow strengths.
Anyone got any thoughts in what the problem is? I am thinking replacement pump.
Mike
Mike
