I have recently moved into a Victorian terraced house and after a week of no problems, the water pressure in the top floor shower and sink has suddenly dwindled to a trickle. However this is for the hot water only. Cold tap and shower (if only cold) is fine. Also, when I first turn hot tap on, pressure is ok for 1 or 2 seconds but then reduces to a trickle. And the water NEVER becomes hot.
I have found a Stuart 2mB pump in the loft (same floor as bathroom) which is only 16 months old which seems to be working (at least it makes a noise, even when hot and/or cold taps are on).
I have no other problems with water pressure/temperature on 1st floor or ground floor rooms...
Any help/advice gratefully received!
