Hello all, as those of you that have read my previous posts will know, I'm spending much more time under my bath than I would care to remember recently.
Anyway, I'm suffering from vibrating pipes under my bath when switching off a tap (full pressure) or when the toilet stops filling (so, a minor water hammer situation really). I think I've figured out a way to remove some of the pipes so that I can clip them, but I'm severely limited in terms of what I can clip once I get behind the bath, as the drill can't fit in there!
PROBLEM: One of the things I've discovered to be contributing to my moving pipe problem is that the top pipe (hot supply) is being pulled down by the dubious way that the hot supply for the shower (GREY PLASTIC PIPE) has been attached to it.
View media item 59395View media item 59396As you can see from the photo, the cold supply pipe uses an 'elbow' and is supported by the floor. However the hot supply is not supported, so it pulls the corresponding supply pipe down, and without enough clips, this is causing movement when full pressure is suddenly removed. In fact the hot pipe gets pulled down to rest on top of the cold pipe, so when full cold pressure is removed, BOTH pipes vibrate.
I'm sure this is not good and I'd like to fix it. This shower to supply pipe connection looks like a compression fitting - am I right? I did some homework on how these work, but if someone could suggest the right parts to buy and sequence to connect them in, such that the hot supply ends up looking like the cold (ie: supported by the floor) I would appreciate it!
NOTE: I can't use a 'straight down to the floor' connection for the hot, because the cold supply pipe is in the way.
Would appreciate any help, getting desperate to get the tile back on the bath now!
