Hi - if anyone has any previous experience on this type of problem I would really appreciate your help.
I have recently moved into a 1945 ish house. The electrics have been updated but not I suspect in the last 10 years at least. I have almost completed redecorating the living room. This included moving the light switch box from one side of the door frame to another. I was very careful to replicate the wiring configuration that was in the existing wall box to the new wall box which I fitted. The room has 4 wall lights that are daisy chain linked back to the wall box which was and will be again a dimmer switch. There is a live, neutral and earth 3 of the lights have two sets of cables and the last has one - no problem there - where I do have a problem is that the only other wire that was present in the original dimmer switch was one permanent live - what I should have done is recorded exactly how the original was wired (hindsight is a wonderful thing)
So the question is how do I wire up the new dimmer to the cables that I have available - sleeved cable with live, neutral and earth to the lights and one permanent live?
Many thanks to anyone who can help.........
