Help. Switched Heating on and pressures gone to 4 Bar
7 Dec 2010
Birmingham
Have came down this morning and switched heating on everything worked fine then after 15 minutes a pipe underneath the boiler started leaking (small spray) and the water pressure was reading off the scale switched off straight away and pressure dropped...
Any suggestion asap please?
BAXI Combi Boiler.
ANy help or pointers greatly appreciatted
H.
Sounds as if your expansion vessel has failed AND you've got a frozen safety valve discharge pipe. Please get it checked!
