Help! Valiant combi boiler pressure dropping…
29 Jul 2021
I need advice, my Valiant combi boiler, which is about 8 years old, pressure keeps falling day by day. I have had the Expansion Vessel replaced and PRV replaced, anti-leak stuff put into the system. Nothing has helped! There’s no signs of water or leaks anywhere. There are no pipes under the ground for or embedded in the walls. I even got a leak locator guy out who couldn’t find anything either or anything wrong with the boiler.
I’m at my wits end with it! Please help!
Turn the boiler off, and redirect the condensate into a bucket, then repressurise the boiler. If the bucket fills up, your main heat exchanger has failed
Thanks! I’ll have to get a plumber to that for me as I’m disabled.
I don’t if it would be the Heat Exchanger, wouldn’t that affect the hot water too?
Does the pressure increase at all, or just drop? Has it been isolated from the heating system?
The pressure just drops. No, I don’t think my usual plumber isolated it from the heating.
