I've just got back from a business trip and when I came into the hall, there was a puddle of water on the floor and a steady drip coming from the ceiling.
I went straight upstairs and found a lot of water in the airing cupboard directly under the cylinder and have quickly traced the source as some sort of vent valve on the top pipe of the water heating coil.
I have been doing some plumbing recently but not on the hot water circuit.
But I have had to drain down the central heating circuit a couple of times and indeed at the weekend, after refilling, I've not got heat from one of the downstairs radiators.
So, all in all, very confused. Has the vent valve (not sure what it's called) simply failed, or have I caused a different problem which has caused pressure build up in the hot water heating coil circuit.
The water heating control was off when I got in but the CH was on and most of radiators are warm.
Any help very much appreciated
Steve
Steve
