Afternoon, I am in the process of replacing my compressor in my garage. I have 3 phase supply and and trying to figure out how to wire it in. At present i have 3 phases and earth going into an isolator and then to the old compressor.
My new one (to me but second hand) has turned up and is prewired to a 16A red plug with 3 phases an earth and a neutral.
I don't think i can take off the plug and use the old isolator as it does not have enough terminals, also in the plug all wires are red - one to L1, one to L2, one to L3 and two to N.
I take it i need the neutral? it has a triangle picture on the wiring plate.
If i run a piece of 5 core from the fuse box (3 phases, 1 neutral and 1 earth to a Red 16A socket and just plug it in will this be the best method?
Thanks in advance.
Thanks in advance.
