Help with Accenta G3 alarm please
12 Mar 2008
London
I have one of these which went off last night when we had a mini-power cut of a few minutes.
The battery was last changed 4 years ago so I'm assuming that it's time for a new one and am hoping to save myself the hundred quid or so it cost last time for the installers to come out.
Have googled the engineering info (http://www.tlc-direct.co.uk/Technical/DataSheets/Ade/4pi175_A-G3_inst.pdf) the system and found under battery
Accenta/Optima G3
mini/compact - 12V, 1.2
or 2.1Ah
Accenta/Optima G3
- 12V, up to 7Ah
Am I right in thinking that it's the second one - 12V, up to 7Av that I want - and when I go into the shop, exactly what do I ask for? e.g. "a house alarm battery 12V up to 7Ah" or do I need to know a particular physical size or something else?
Also, once I've got it, please could someone help with instructions for a very UN-diy person as to EXACTLY what to do from walking in the front door with new battery under arm in order to replace it?
Many thanks not only from me, but also the neighbours!
take the old one with you.
maplin sell them
12v 7Ah
the also happen to sell the best brand Yuasa
That's not the same as the operator's code is it? That's in the green booklet I have. Damn thing doesn't say anything about how to replace battery though. If it's not, is there any way of finding out? Do you know if it's a default or if each installer puts their own one in to try and get the repeat business?
thanks again
yes installation companies do change the factory default engineers code, but just open it and use your code to switch it off
Breezer, forget me for being dumb here - but do I need to turn off the circuit that it's on before wielding a screwdriver so I don't electrocute myself. Or is it enough to turn off the switch at its personal fuse box? (Would I need to take the fuse out as well?) And when I do that, would it not set the alarm off so it would be wailing for the length of time it takes me to unscrew the front of the panel, get the battery out and then replace the panel? Or could I just leave the front of the panel open once I've got the battery out (do you know if it's something that needs unscrewing or does it just pop out like in a torch) and then switch it back on at its fuse box? I'm just trying to not subject the neighbours to the noise again.
Thanks for your patience.
no dont turn the mains off, that would be the wort thing to do.
just dissconnect the battery before you go to maplin
Breezer (or anyone)
progress has been made - the old battery is out, the new battery has been bought. Next silly question - does it matter whether you attach the red or the black first when connecting the new battery?
Thanks again
