    Dismiss Notice
Help with automatic bypass valve
Discussion in 'Plumbing and Central Heating' started by sastek, 14 Oct 2016.
  1. sastek
    sastek
    2 Oct 2013
    12
    Thanks Received:
    Country:
    Hi everyone,
    I have just fitted an ABV to my heating system to replace an old manual gate valve, but when I contacted the boiler manufacturer, Trianco, to ask what the minimum flow requirement for the boiler is, they told me that they could not find this information.
    So I wanted to ask you experts if there is a default minimum flow value that I should use to setup the ABV? I now have an s-plan setup so in theory the ABV should never be needed.
  2. Sponsored Links
  3. Terrywookfit
    Terrywookfit
    19 Jul 2007
    5,739
    Thanks Received:
    1,086
    Country:
    Which boiler is it ??
  4. ianmcd
    ianmcd
    15 Aug 2010
    22,669
    Thanks Received:
    9,093
    Lanarkshire
    Country:
    Why would an ABV not be needed on an s plan system it is always needed on an S plan you normally get away without one on a Y plan I think you are getting mixed up
  5. Terrywookfit
    Terrywookfit
    19 Jul 2007
    5,739
    Thanks Received:
    1,086
    Country:
    Going by the name "Trianco" unless it is a surviving Triancogas (which I would very much doubt).
    My guess is an oil fired boiler that does not need one.
  6. 45yearsagasman
    45yearsagasman
    14 Mar 2010
    6,089
    Thanks Received:
    1,092
    Norfolk
    Country:
    It does if it's an all trv system.
  7. Terrywookfit
    Terrywookfit
    19 Jul 2007
    5,739
    Thanks Received:
    1,086
    Country:
    There should always be a rad permanently open.
    Pump / system noise would be obvious.
  8. sastek
    sastek
    2 Oct 2013
    12
    Thanks Received:
    Country:
    HI, sorry for the slow response. It is a Trianco Eurotrader 90 oil fired boiler. I was told that building regs now demanded an ABV.
    I do have TRVs all round, but plan to remove the one in the room with the thermostat.
  9. 45yearsagasman
    45yearsagasman
    14 Mar 2010
    6,089
    Thanks Received:
    1,092
    Norfolk
    Country:
    Building regs have nothing to do with it. A bypas is required if the manufacturer of the boiler says so. Read the man instructions. A minimum flow rate through the boiler must be maintained. I haven't read the instructions, and if you don't have them, then google them. You may find that having one non trv rad will be OK.
  10. Sponsored Links
  11. slippyr4
    slippyr4
    12 Jul 2005
    992
    Thanks Received:
    30
    Bedfordshire
    Country:
    Building regs do have something to do with it in that they say that a bypass (where required) must be automatic - just using a gate valve is no good.
  12. 45yearsagasman
    45yearsagasman
    14 Mar 2010
    6,089
    Thanks Received:
    1,092
    Norfolk
    Country:
    The OP has fitted an ABV. His question relates to setting it up.
  13. slippyr4
    slippyr4
    12 Jul 2005
    992
    Thanks Received:
    30
    Bedfordshire
    Country:
    Sure. But the OP said that building regs now demanded one, and you said they had nothing to do with it. I pointed out that they do.
    (n)
  14. 45yearsagasman
    45yearsagasman
    14 Mar 2010
    6,089
    Thanks Received:
    1,092
    Norfolk
    Country:
    Ok I stand corrected. Can you help the OP with his problem?
  15. slippyr4
    slippyr4
    12 Jul 2005
    992
    Thanks Received:
    30
    Bedfordshire
    Country:
    If you actually bothered to read the original post, you'd see that he's already been in touch with the manufacturer who say they don't have minimum flow rate data. So I fail to see how you telling him to read the manual is helping him with his problem.
  16. 45yearsagasman
    45yearsagasman
    14 Mar 2010
    6,089
    Thanks Received:
    1,092
    Norfolk
    Country:
    Ok Slip, I certainly don't want to get involved in a key board war of words. I'll retreat and let you guide him with his problem.
  17. slippyr4
    slippyr4
    12 Jul 2005
    992
    Thanks Received:
    30
    Bedfordshire
    Country:
    You're the one that's thrown your toys out of the pram, pal.
Loading...
Share This Page
