Help with baxi combi boiler
24 Dec 2012
Glasgow
I have a baxi combi boiler, how can I increase the temp of my radiators from the boiler. It kicks in and heats until 50 on the boiler board but stops before dropping slightly and then kicking back in again. This happens continuously!! Just had a new circuit board fitted, is this connected to the temp issue??
Any help appreciated...
What model of boiler is it? Have you turned the control knob all the way? Maybe when the PCB was replaced the knob was put back incorrectly so its stopping it go any further?
is the hot water getting hot than 50 degrees?
I would suspect that when the PCB was replaced, the spindle wasn't aligned and its moved, so you think youve turned it up, but the potentiometer isn't turning all the way.
Yep very, call the guy that fitted the PCB and tell him to get his ar$e back here to sort it!
