Hello,
I need some advice on mounting some wall cabinets.
I've got a wall bookshelf (http://www.ikea.com/gb/en/catalog/products/80116676) it's 120cm x 35cm by 28cm deep. It weights about 15kb plus whatever I put in (which will probably be cd's).
It's going on a stud wall (it was only built 5 years ago so isn't old if that matters) but the mount points go into the hollow and I'd rather not take the wall apart to fix noggins.
Would using toggle bolts do the job? If so, can anyone recommend a size. Or even an alternative.
I don't think this matters as I guess it's not the shear weight that counts but it will be 'rested' on the top of a solid wood stand (http://www.ikea.com/gb/en/catalog/products/30133942).
I actually have two of these to mount, one on top of the other
