Help with fuse replacement
28 Mar 2024
I’ve removed the fuse from this holder to change it but somehow have managed to get the screw that hold the fuse holder in place stuck behind the fuse holder. It turns and turns but won’t come out and I can’t push the fuse holds back in place with the screw in the way! Any ideas??? Thanks in advance
Thank you for your reply the problem is that the screw is now behind the fuse holder - no idea how I managed that!!!
If I remember correctly, with the MKs, the screw remains captive.
Try putting the fuse holder back in, and then with some gentle pressure on the holder, turn the screw clockwise, until the screw bites.
Thank you Jackrae was about to post a picture but RandomGrinch just solved the problem! Thank you so much for taking the time to post - all sorted now!
