- Joined
- 10 Jun 2006
- Messages
- 7
- Reaction score
- 0
- Country
I am still having trouble with my new plumbing system. My new system will be based on a Megaflo mains pressurised system. My plumber has advised me that as there is 3 ensuite showers/baths and a main bathroom, I need breaker tank and pump aswell. The only way to avoid this is to make sure the new connection to the mains is with a 63mm connection which is the next connection up from 32mm. After some confusion, Scottish Water are now saying they will only provide a 32mm connection. The mains pipe pressure is high at 6-8 bar. Can anyone advise if the high pressure means I can get away with a 32mm pipe. How is flow rate calculated? Should the plumber be able to calculate exactly what size of pipe is required based on load and pressure? If possible, I would like to avoid tanks and pumps.
Thanks in advance.
Thanks in advance.
