- Joined
- 25 Jan 2017
- Messages
- 22
- Reaction score
- 0
- Country
Hi will try and put as much info as possible on here.
I want to build a hair salon in my garden it will be a of 8.6m wide x 3.3m wide I know there may be height restrictions not sure what they are but this should effect anything.
I will attach a rough sketch to help, there is an existing concrete base from the existing carport which I plan on building on top of I have had builders round that have okayed this as it is only going to be single skim block then rendered roof would be rubber I will then Baton and insulate inside.
I know I may need to apply for change of use as it will be a salon, I’m not sure if I need planning for this, if I do no problem, I’m unsure if I would get building regs due to not putting a footing in, so if I did need change of use would they need to see building regs I order to get the change of use?
On the rough sketch on the right hand side where there will be a partition wall the 2.2m x 3.3 is a small garage just an fyi.
Any advice would be appreciated greatly. Thank you
