Hi All,my first post so please be kind.I have a rather elderley heating system using 2 motorised 2 port satchwell valves type sd2301 i think (identified from google images).The problem im having is the radiators get very hot when i put the hot water on but not when i set the programmer to heat radiators.I think i have deduced that the motorised valve for the radiators is not working( i can see the hot water valve indicator on the top rotating) but the radiator valve just buzzes slightly but dosnt seem to turn.Is there a direct replacement? and also does the plastic cover come off to try and see whats going on.Does it clip off i dont want to break it.
I Hope this makes sense and thanks in advance for any replies
