help with three way switch
Do you mean convert the existing light switch to a 3-way arrangement by adding another switch, or do you mean leave the existing light as it is but take power from the switch for a completely new light which has 3-way switching?
Yes leave exsisting light switch as is but take power from the switch for a completely new light which has 3-way switching can it be done and how :?: :?: :?:
Not sure about the usa but i don't think you would have a neutral in the existing switch, so it would be a no-no.
It will depend upon the wiring method used for the original switch. Loop-in is by far the dominant method in the U.K., but in the U.S. it's also common to take the feed directly to the switch and then on to the light, since the same circuit may also be feeding nearby wall receptacles.
You'll need to remove the cover plate of the switch and see what wiring is in the box to determine if it will be possible or not.
