Hi, my cousin has had a new pump fitted to her boiler. There was no other work carried out. The fitter said that he got an electric shock from the 'earth' from the room thermostat (twin and earth cable)
I investigated, and found that there was 240 volts in both the brown and the green/yellow cable from the thermostat. I take it that is not normal, but am unsure as to how the thermostat works - is it just an electric switch controlled by the dial? If so, therre should no reason for 240 volts in the earth cable.
Can anyone confirm my opinion? Any suggestions? Is the thermostat faulty?
The heating works OK, and so does the water. Thanks guys!
