hi. im in a fix.
i have a glowworm combi electronic. hot water comes out of kitchen sink which is next to boiler. 1 bed flat. however there is no hot water from b/room sink (non mixer ) or shower!!! i had builders in. at first i thought it was crossed cold/hot pipe. however when i run hot tap in kitchen then run hot tap in b/room a little bit of residue hot water will come out of b/room tap. this tells me pipes are fine. water flow is fine. i had two guys come. theys said it boiler , no explanation!!! how can boiler switch on for one tap and not the others?guys says i need a new boiler too. pls help. thanks
