Hep2o stop tap
I think with the lever valve facing the front I wouldn't be able to shut the inspection panel
Better to do this then try and repair the plastic one? If can swap the top body of it
Guess you've never seen an access panel that clips off front ways? Instead of hinged
Thats the valve split
Thinking of splitting it and just swapping the head. Or at least having a look at it
Would you give option of either repair or cut out back of unit for a brass valve?
